Helmsey
Dec 31, 2014Explorer
otrfun wrote:
My next truck (4x4, CC) has to have a minimum 3000 lbs. of payload. That leaves me with either a 1 ton diesel (3500-4000 lbs.) or a 3/4 - 1 ton gasser (3200-4000 lbs.).
I've run my gasser vs. diesel numbers as far as purchase price, MPG (towing & empty) and resale.
I'm familiar with what's needed to maintain a gasser; however, never owned a diesel. Here's what I know, don't know, about diesel maintenance:
1. Oil costs are approx. double vs. a gasser due to twice the oil capacity.
2. Oil filter. I assume these cost a bit more than a gas oil filter?
3. Fuel Filters. Assuming DIY replacement, what can I expect to pay for filters? How often?
4. DEF. 2-4 cents of DEF used per a gallon of diesel??
5. Valves. Under normal operating conditions is adjustment ever necessary? If necessary, cost?
6. Injectors. Under normal operating conditions is maintenance/replacement necessary? If necessary, cost?
Other diesel specific maintenance items I may have overlooked?
Thanks!
1. It cost a little more, but do it less. I change my oil about once a year according to when the truck tells me its time.
2. Maybe, but again don't need it as often. A quick google search shows my oil filter anywhere from $15 - $22 and that is for the Motorcraft part.
3. For my truck the 2 filters are in the $50 - $60 range and I change them every 10,000 miles
4. I have put about 12000 miles on my truck this year and have added DEF 2 or 3 times, at $12 for a 2.5 gallon jug at Wally World.
5. I have not had any adjustments to mine
6. I have not had any adjustments to mine
