โApr-05-2019 07:16 PM
โAug-13-2019 09:22 AM
โAug-13-2019 07:23 AM
BenK wrote:
Also, the Ford Explorer rollover begot lots of these labels and tire PSI monitoring...managed to the idiot and gorilla...
โApr-10-2019 05:52 PM
โApr-10-2019 12:15 PM
OP wrote:
Thanks for all of your input though, Im feeling pretty good about my choice..
โApr-10-2019 09:38 AM
โApr-10-2019 08:43 AM
โApr-10-2019 08:41 AM
โApr-10-2019 08:38 AM
โApr-10-2019 03:24 AM
โApr-09-2019 09:57 PM
Rustycamperpants wrote:
I moved up from "Heavy Load" tires on my Expedition to real "LT" tires. Max air pressure on the new tires is 80#, max pressure on the heavy load tires was 50#. I always ran my other tires at max pressure when towing my TT.
I talked to the tire installer and asked him what they set the pressure at and he responded, "To whatever is specified on the door sticker". This will be in the 36 - 38# range.
What do you all do? I was thinking all along I should run much higher pressure on the LTs just like I did on the heavy load tires. Thanks in advance...
โApr-09-2019 08:59 PM
Ralph Cramden wrote:Grit dog wrote:
I can say heartily that "engineering" is an ever changing blend of the theoretical solution, the practical solution, the politics, the cost, the liability involved with the particular solution and the human opinion or error aspect.
That's a good one.
BTW, did anyone mention nitrogen in this thread? Now off to pump up my tire and see if I can blow the valve stem out of it.
โApr-09-2019 03:50 PM
โApr-09-2019 12:46 PM
โApr-09-2019 12:13 PM
