- facoryExplorerSure you can.
- Old-BiscuitExplorer IIIFrame......can't jack on torsion axles
- facoryExplorerJack up the wheel you want to work on just enough to get it off the ground. Chock all other wheels first.
- dcooper67ExplorerI want to raise the wheels to repack the bearings.
- profdant139Explorer IIDo you mean raise the wheels or raise the chassis so that you have more ground clearance?? If the latter, there are kits for torsion axles. Figure out which ones you have and then contact the manufacturer of the axles.
- westendExplorerI jacked my trailer up using the frame but I have full box frame with an angle iron mounting plate.
About Travel Trailer Group
44,026 PostsLatest Activity: Mar 01, 2025
