- kw_00Explorer
NJRVer wrote:
kw/00 wrote:
Braking Module? youtube that...I think its that small black box that sits above the spare tire attached to the frame. If so I would ebay that part and get it for a fraction of the cost. I cant recall but the guy on you tube replaced himself for under 100.00. It may cost more but nowhere near what the dealer is quoting you....Check into it! and let us know
I looked up above the spare and the only box was an emission vent.
There is a major junction block where the main harness comes back and all the other harnesses for backup sensors, license plate lights, trailer plug, tail lights, etc. plug into.
Yep that main box is the one I'm thinking that they are going to replace but I could be wrong. Thanks for all the updated info, I am keeping my eye on this topic since it is such a common issue on these trucks. Let us know what the replace and get that old part and take a pic if you can so we can see what was replaced. Thanks again. - NJRVerExplorer
There is a major junction block where the main harness comes back and all the other harnesses for backup sensors, license plate lights, trailer plug, tail lights, etc. plug into. - hawkeye-08Explorer IIItowing 10,000lb bumper pull with 2011 GMC CCSB 4WD 6.0/6sp/3.73
mpg depends on speed/wind and hills. I generally tow 58-60mph and get 8.5mpg, faster 65mph drops 1mpg down to 7.5mpg or so.
I should have ordered it with 4.10 gears, the speeds I tow would have a few more rpms and reduce the downshifting some. I have plenty of power, just like to get decent mileage. - yellowdog00ExplorerJust finished a tow from IL to MT with truck and fiver in my sig. Truck said I averaged around 8 mpg. I like truck except for integrated brake controller. Put a Prodigy P3 on it that Made a difference. There are other threads on this issue.
- NJRVerExplorerThere was a pretty long post on duramax forum that somebody posted about the tie in of the different modules that all effect the braking.
Pretty interesting about how one little thing can throw everything out of wack.
Trailer braking, regular braking, cruise control, ABS, speed sensors on the wheels, etc.
I looked up under my dash after reading the post and there is a brake switch that I read about in other searches, but also a large solenoid also attached to the pedal. The post also mention another brake box behind a kick panel I believe.
Once they get the part and the work done I should be able to post more specific info such as actual part# etc. - kw_00ExplorerBraking Module? youtube that...I think its that small black box that sits above the spare tire attached to the frame. If so I would ebay that part and get it for a fraction of the cost. I cant recall but the guy on you tube replaced himself for under 100.00. It may cost more but nowhere near what the dealer is quoting you....Check into it! and let us know
- NJRVerExplorer
kw/00 wrote:
NJRVer wrote:
'09 Chevy 2500, 6.0 towing 28'TT.
No issues except my DIC started with a "service trailer brake" warning the other day and now I have no trailer brakes.
Goes to the dealer Monday to find what is wrong.
I had this same issue once just for a min and have never seen it come back. I did google it a while back, even found a youtube video on it. Looks like a simple fix. Could also be water that leaked into the connections. I have never had the light show back up or any issues with it stopping my trailer so keep us in the loop of what the dealer says. Youtube it and u will see that there is a small box behind the spare tire that gets replaced and a fuse in the engine are fuse block. Hope this helps.
Ouch!
Came back from the dealer.
There is some sort of braking module that is bad.
It does cause codes to pop up so it was easy for them to diagnose.
Problem is GM has it on backorder so I have to wait.
Cost will be about $1000 to fix and they said they need my truck for the better part of the day. - Blazing_ZippersExplorer II2016 Ram CC, 6.4 Hemi, 4WD,373 gears.
Trailer now is a Cougar fifth wheel weighing 10,300 max.
This combination seems to be vey good! We just towed from Bend, OR. to Sacramento, CA and then back to Coeur d Alene, ID. Good results.
EVIC showed 10.2 average, at about 60 mph. I didn't hand calculate mpg.
We're really happy with the combination so far, other then the truck sits high enough where we have had to make trailer height adjustments. - Need-A-VacationExplorer
jerem0621 wrote:
I am enjoying reading all of these gasser posts. Mine was a 99 V10 CC Dually F350. It was a strong truck...I didn't like the seats as they were not very comfy for family travel. I would like another gas hd truck in the future...probably a F250 Lariet. Thanks! Jeremiah
The couple times we checked the Fords out at the auto show we were never impressed with the seats either. Felt like a park bench they were so firm. Just wasn't for us. Though we haven't looked at the Fords in about 10yrs.
Has been a very good read!!! And good to see IB on the site!!! - NJRVerExplorer
That would be nice.
I also read on one of the truck sites, somebody posted a page from service manual that had something about a sensor in the mastercyl.
Either would be ok with me.
I just don't want to go through a complete wire by wire front to back check. That would cost$$$.
All other light terminals work fine. just no power to electric brake.
Also been dry as a bone here for weeks so no rain seeping in somewhere.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
