Grit_dog
May 03, 2023Navigator III
Wandering feeling, absent of any worn components, which is a reasonable assumption given your truck is new, is often not enough positive caster. These trucks have adjustable caster cams in the suspension arm mounts.
Worth mentioning as it wouldn’t be the first truck to come off the assembly line this way.
Another cause of wandering is any negative toe.
Edit: Or if you have the camper set back on your new chassis where it’s removing a significant amount of FA weight, that could contribute to the wandering feel. Haven’t seen how your new truck is setup.
44,060 PostsLatest Activity: Jul 17, 2025
