JRscooby
May 04, 2023Explorer II
Grit dog wrote:JRscooby wrote:
Don't know where in Ok you are, but it is not rocket surgery. Document the dealers can't/won't do the work. Look for any real truck dealer. (KW, FL, IHC, Pete, Volvo) Sure, you will have to go into your pocket, but get a 4 wheel alignment. Maybe if you can show you had problems from jump you might get repaid.
4 wheel alignment? Lol :S
I understand anytime you see I post something you feel it is your duty to attack in some manor.
Back when I was trained on front end alignment, the machines where designed to compare front wheels to each other. (GM Training Center, 1970) This may or may not find the issue OP is having.
Now the OP is talking he has had issue from start on new vehicle. If we discount the idea of damage before delivery (Possible, and if it happened the selling dealer might want to hide it) then we must assume something was not installed right from the factory. Maybe it is just timing off between the steering wheel and front wheels. But it could be something off causing rear axle not to be perpendicular to frame. If I had bought a new truck, (or even more than a few used truck) and it did not drive right I would want a expert, with no ties to seller, to check first the rear axle was square to frame, then be sure front wheels are properly aligned to rear wheels and each other.
44,026 PostsLatest Activity: Mar 01, 2025
