B_GAGE's avatar
B_GAGE
Ram Wheel to Wheel Steps & Torklift
I have a 2015 Ram 3500 with the Wheel to Wheel side steps needing camper mounts. Torklift , manufactures a set made for this purpose however, their tech support says they go under the steps which sounds like they could possibly create a ground clearance issue.
Are any of you using the Torklift system on a similarly equipped truck & are there any issues with ground clearance?
Thanks,
  • They go under the steps. I have the factory steps / running boards and there is no room (at all) to go over the steps.
  • Chad, after modifying, do they go between the steps and bed or under the steps?
  • I have a 2014 Ram 1 ton, 4x4 single rear wheel. When I contacted Torklift they did not have a solution for the wheel to wheel factory steps. I modified the standard fron insert by cutting it in two and welding in a drop. I works just fine.
    I will attach a pic of it if I can.
    You can email me directly if I can not get the pic to attach.
    I see I don't remember how to attach pics. I figured this out a year ago, but don't have time to devote to it now. Email me and I will send you pics if you would like to see them.
    Chad
