rexlion's avatar
rexlion
Rear axle ratios and impact on towing
Suppose you have a choice between two axle ratios, say they are a 3.09 and a 3.45. And let's say the vehicle has an 8 speed transmission, so there's plenty of gear flexibility. Ok, so there's roughly a 10% difference in RPM for any given gear to drive the vehicle at a certain speed. But won't the tranny simply choose a higher gear to offset the 10% difference in rear ratio, so that in the end the engine will run at pretty much the same RPM as otherwise? Or am I not understanding how it works?
Before you tell me how lousy a 3.09 is for towing, I should say that my current TT is pretty lightweight anyhow.
