mleekamp
Sep 08, 2021Explorer
When we had a TT (several actually), I always added a spare tire and bike rack. I could tell the difference, though not a huge one, when having 4 bikes back there vs. none. Never really towed w/o the spare.
I will note that in the front basement of our TT, near the hitch, I had a grill, hammock stand, all kinds of stuff...so with 4 bikes it did balance it out. So like you said, relocating items (my grill was originally stored in the back, but I moved to front) is a common fix.
As far as sway, we used a standard friction sway bar, and we had no issue. I think overall, in general terms, your initial set up is critical to an enjoyable tow. I'm talking 1st time with truck and trailer, loaded. I'm sure you know that. Personally, I'd be carefull adding too much weight back there.
BTW, our current Class C, I added a spare tire carrier and spare...the carrier alone was HEAVY -- solid steel -- to carry the 200lb (guestimate) spare tire. The carrier also allows me to still tow a car flat down or trailer. On the C, on a 450 chassis, I don't notice it at all. You probably experienced the same on a C...
44,027 PostsLatest Activity: Apr 19, 2019
