Jan-12-2014 04:59 AM
Jan-13-2014 06:08 PM
beemerphile1 wrote:Atlee wrote:
Mine is Auto & LP. On Auto, it will use AC when available, but automatically switch to gas when AC becomes unavailable. If for some reason, while pluged in to shore power, I still want to use LP for the fridge, I use the LP button on the fridge.beemerphile1 wrote:Bears Den wrote:
Mine has a switch for electric and gas only.
You sure it isn't electric and auto?
Set it on auto and it will take care of itself. When you plug into electric it will switch to electric. When you unplug it will switch over to LPG.
You're right, LPG or auto, my mistake.
Jan-13-2014 03:42 AM
Jan-13-2014 01:43 AM
Jan-12-2014 05:53 PM
Jan-12-2014 01:56 PM
Jan-12-2014 12:58 PM
Jan-12-2014 11:17 AM
Jan-12-2014 10:54 AM
Sandia Man wrote:
I don't overthink it, I just set my fridge to auto and let it function as designed whether camping down the street or going cross country.
Jan-12-2014 10:13 AM
Jan-12-2014 09:01 AM
Jan-12-2014 08:55 AM
CavemanCharlie wrote:
Run it on gas. Mine has a auto switch. It automatically switches to gas when I unplug.
Be aware though that the first time you do this you will have to purge the air out of the lines. Best way to do this is to turn the gas on and then try to light the stove. Once the stove is lit then you can switch the fridge to gas or, unplug the camper with the fridge switched to the automatic setting. Then it should light itself. It will try 3 times to light and if it doesn't it goes into "lock out" mode and glows a red X on the front panel. If this happens just slide the switch to off, and then back to gas or auto, and it will try 3 times again. Mine usually will light on about the 4th or 5th try the first time. After that it fires right up on the first try.
Jan-12-2014 07:21 AM
Jan-12-2014 06:58 AM
Jan-12-2014 06:32 AM
