Powelligator wrote:
Been there, done that.
My 1995 Lance has an RM2510. (I think) I also wanted to update to a newer, more modern design but the physical layout of the cabinetry wouldn't allow for any other sized reefer. To get a new reefer in you have to partially disassemble it, as it won't fit through the door otherwise. It appears that the camper is built *around* the refrigerator.
Joe
When I went to pick up my camper, they had installed the wrong fridge. Fortunately I picked it up at the factory so the change out was done there. They had to remove the rear door to get the unit out/in. It was only a handful of screws then fighting the EternaBond used as a sealant, but they still ended up bending the door frame and put a new one on when finished, again another reason I was glad I picked it up at the factory.
I'm hoping I never have to replace the fridge...
