SoundGuy wrote:
GrandpaKip wrote:
While on a scale, my 2 grandsons, 104 lbs., got on the frame attached cargo rack. They unloaded the tongue 20 lbs. Not a big deal. There is typically less than 100 lbs. on there when traveling.
In many cases it can be a big deal. That's 100 lbs of bouncing weight as far aft of the axles as it could be so the effect is magnified in a real situation when rolling down the highway. Secondly, while this may not have much negative affect on tongue weight for a 30'+ trailer running 1000+ lbs of gross tongue weight it sure can for a much shorter 20' running half that. :E
Umm..20 pounds less. 560 pounds TW to 540 pounds TW. To me, not a big deal. Everything is strapped tightly down to the rack. No room to bounce. The rack is bolted to the frame and doesn't move.
If you mean the trailer bounces more, that I haven't noticed. In about 10,000 miles, I haven't noticed nor felt any difference in handling.
But, I'm not planning on putting any more weight back there, either.
