MrKen's avatar
MrKen
repairing eye bolt tie downs on 2003 Pastime
I've been here awhile, my first question though. The camper is in very good condition, except I need to replace the rear eye bolt on the Pastime 2003 camper. It was a bit loose, couldn't tighten it because the nut was rusted on the eye bolt, didn't know that until I removed the propane tank and housing. So there is about a 4" x 4" area the plywood dry rotted, the 1x3 strip going front to back has about an 8" length that needs to be replaced.
Any suggestions on how to fix? I prefer not to take off the jack siding, and such, unless that is what I should do. I'm thinking an aluminum plate nut and bolted to the good plywood and the new eye bolt attached to that, along with the 1x3 area replace with a good piece of oak. That should/could be stronger than just the original nut inset into the plywood. Any pics, suggestions, directions, advice will be good. Thank you,
Ken
  • Youngm3571 wrote:
    On my old camper I had this problem and ended up adding an “S” shaped metal hangar to each of the rear jacks by adding a longer bolt to the bottom of the bracket. Worked for many years.
    Is there any potential problems doing this? It seems like a much stronger connection point. Is there a reason why the manufacturers don't do this?
    I will try for the photo bucket account to post pics.
  • On my old camper I had this problem and ended up adding an “S” shaped metal hangar to each of the rear jacks by adding a longer bolt to the bottom of the bracket. Worked for many years.
  • I did go there, and I have a warning the site is not safe, so I left.
    Thank you,
  • You should find help in forum stickies how to do it, but this is popular hosting site for pictures http://photoposting.is-great.net/?i=2
  • I do have pictures, I don't know how to post a pic.
    I did some searching, but I still didn't figure it out.
  • Picture?
    If the wood is not totally rotten - fiberglassing is very good way to fix it.
    Camper frames are pretty hard to repair as they are wood members stapled on both sides, so each damage needs to be well assessed.
