Son_of_Norway
Jun 24, 2013Explorer
If you have a good converter that has a float stage your battery shouldn't overcharge. Check the specs for your converter and determine if it does have a float, or what could be described as a lower voltage maintenance stage, about 13.1 volts. Then check the voltage while your converter is charging with a multimeter and make sure it is working correctly. Hard to say what might have been the problem with the other battery, check your batteries on a regular basis to make sure they have adequate electrolyte and they are holding a charge.
By the way, welcome to the forums!
Miles
Miles
