waynefi's avatar
waynefi
Replacing water tank
My fresh water tank has a leak, so I am trying to replace it, but I can't figure out how to get the old one out.
There are two side-to-side rails in the front and rear of the tank. The back one is screwed into the trailer frame. The front one looks more permanent. There are two lengthwise rails that have tabs that drop into slots in the sideways rails. So the obvious thing is to lift the lengthwise ones, then slide the back rail back. But I can't lift the tank, because it is up against the bottom of the trailer. I can't move the back rail with the tabs still in place. So how do I get the tank out?
Has anyone else seen this arrangement?
