Gjac wrote:
This has been very informative to me and have formed some conclusions based on your comments. Most people reported that a WDH or anti sway bars are not required for a 3500 lb or less TT. I have no problem backing a 19 ft boat down a ramp so I can't see a 19 ft TT being much harder. As far as ride quality after reading on this forum all the handling issues of the F-53 chassis and these short 24 ft Class C with light front ends a truck and TT combo should ride better. One thing not mentioned a lot on here, is each tire carrying the same load for a good ride. My old P-30 chassis has this and I drive it with one hand like a car even with passing trucks without all the suspension addons people buy to fix the ride. My only concern was the added tongue weight from the TT causing the front end to be lighter. Only one person said a special HD package was needed most said any 1/2 ton truck would be fine. My right arm is still good so I can crank the tongue jack on my boat now, not sure how much different the TT would make. As far as leveling it would appear easier than a small C because you only need blocks for one tire vs 3 for a C(one for front tire 2 in rear for dual wheels). I fully realize setup was going to be more difficult than my Class A with auto levelers and in over the last 15 years and 100k miles I can only remember a few times setting up in the rain, because when it was raining it was much easier and safer just to pull into a WM for the night than to pull into an unfamiliar CG in the dark. So have I come to the right conclusions am I missing anything?
Boat trailer and TRAVEL TRAILER are two completely different beasts when it comes to towing and handling.
Boat trailer are intentionally built with the wheels much farther back than a travel trailer. Has to do with how the weight of a boat is distributed. Boats have considerably more weight on the back where the motor is and they are wider in the back so to get proper handling the axles must be further back. Boats are also much more "aerodynamic" and have less wind drag..
Boats you can easily tow without WD and not affect the vehicle handling or front end feeling.
Travel trailers are more balanced with wheels much more forward than a boat trailer. If you are planning to forgo the WD, then what you will notice is the front end "porpoising" up and down, may feel a bit like the front is floating some. This feeling may or may not be acceptable to you.. The same feeling happens when you have a big heavy TC in the back of a pickup truck..
This is also one of the reasons why getting max tow/max payload option even with a proposed 3500 lb trailer, this option upgrades the springs to a firmer higher rate which will definitely help control the porpoising feeling.
For leveling side to side, yes, just need to place blocking under the trailer wheel(s) on the low side. I have dual axle so I carry one 2x10 that is long enough to fit both tires on it. Tapering the ends with a 45 degree angle helps ease the tires on and off, a lesser angle works even better but that requires the board to be longer yet.. Works very well. One 2x10 typically gets me level enough in most parking lots and even campgrounds if I am choosy where I park.
Once you have the side to side leveled out, then you can use the tongue jack from front to back.. For overnighting you might not be able to get front to back leveled out easily since you would most likely would not unhitch. Sometimes just moving the vehicle around the lot you can find spots that will work out fine without much front to back leveling.
