Andym133's avatar
Andym133
Rhino Roof
Has anyone ever tried the Rhino liner spray for the roof instead of the rubber? I saw a video I believe from this site and would be very interested to find out where this could be done. I live in Pensacola Fl and haven't even heard of anything like that around here.
  • If you are still looking for a roof answer check out this company. RVRoof.com I know people who have been there and are extremely happy. This is all these guys do and their product is made for RVs only.
  • Peterson Ind. Offering New Rhino Roof System
    February 21, 2013 by RV Business
    Smith Center, Kan.-based Peterson Industries Inc., manufacturer of the Excel luxury fifth-wheel brand, will be offering the Rhino Eco-Coat roof system on all Winslow and Wild Cargo model units. According to a press release, Peterson is the first OEM to use the new system from Rhino Linings Inc.
    Peterson said Rhino Eco-Coat system is virtually problem free and offers many benefits, including:
    • Maintenance free.
    • 100% seamless.
    • Energy efficient – reflects sun UV rays, reducing temperatures up to 20 degrees.
    • Fire retardant system meets UL 790.
    • Can be easily patched when new equipment is added to the roof.
    • Not easily damaged like EPDM and TPO roofing material.
    • 2-year product and application warranty.
    “This new roof system provides the same toughness you’ve grown to know with your Rhino truck bed linings with the added benefit of UV protectant for greater reflectivity,” stated Bryan Tillett, president of Peterson Industries. “We are extremely excited to be in partnership with Rhino Linings and be the first manufacturer ever to offer this superior roof system on an RV.”
    http://www.rvbusiness.com/2013/02/peterson-ind-offering-new-rhino-roof-system/
  • I had rhino liner applied to the plywood floor of my cargo trailer. it is HEAVY!! rhinoliner is more flexible than LineX. It has worked great as a floor in my trailer, but from my experience I wouldn't even think about using it on the roof unless they have reformulated it considerably for roof applications. The reason is that even with good prep, it doesn't stick to plywood near as well as it does to metal. And it does have a tendency to develop small cracks when if flexes. I'd be concerned that it wouldn't make a good long term seal over the roof decking and trying to get anything to stick to it along any edge seams could be very hard. I haven't found anything that will stick to the rhinolining on my trailer floor when I tried to seal the edges as they wrapped up onto the walls. Silicone, dicor, eternabond, sitkaflex (sp?) will peel right up.
    Now if they have reformulated for roof applications it may be a completely different story.
  • I believe Rino Liner is now marketing a roof system. It is basically the same stuff only much thinner since a roof does not get the same abuse as a truck bed, and the stuff is quite heavy. Since they use less product it should reduce the cost, but not likely. Prep is the key to success.
  • Proper preparation would be key to success, otherwise you will have a big mess on your hands
  • Interesting, but would it even adhear to the exisitng rubber roof? I know when they did my truck bed there was a lot of prep required.
  • It's becoming a popular solution for RV roofs. You can actually do it yorself fairly easily from what I have seen. There are some videos on YouTube
    Search for herculiner RV Roof or spray on RV roof. Herculiner is a rhino like product you can get at most auto supply stores. It can be rolled onto your RV roof and seals just like the rhino lining will. It's a lot less expensive.
