AcdiiExplorerApr 18, 2019Roof coatingThe 5 YO roof on my Coleman is starting to show black across the trusses, which is the coating wearing off. Last fall when I washed and protected the roof I tried scrubbing to see if it was on top or ...Show More
gboppExplorerApr 18, 2019X2 on the Heng's Rubber Roof Coating. It did a good job for me and is holding up after tbree years. No primer is needed and is easy to apply. I used 2 1/2 gallons to cover 30' of roof with two coats.There are other coatings available, check them before you decide.I'll use Heng's again.
Related ContentRe-coat roof already?rubber roof coatingRoof CoatingFiberglass Roof CoatingRubber Roof Coating on Fiberglass roof
