silversand's avatar
silversand
Rotted out under-tub Caribou 8
Just a heads-up to those with Outfitter Caribou units with wooden tub: there is some kind of very cheap furniture veneer under the entire tub glued to the floor XPS foam and aluminum beams. This has absorbed water between bed of camper and rubber bed mat, and completely rotted away. I just found it this morning. Another to-do (after I found a section of wing under battery compartment) completely rotted out on this camper last Fall. This repair will be about 20 hours this Spring. LOTS of wood on these campers. Ours is 9 years old this May.
Thank God this stuff is only cheap veneer and not structural, so I can glue a ~2 sq foot sheet of 1/16th plastic FRP to the aluminum frame and XPS. I wish could remove it all, but the glue in some places is still tenacious with veneer. Expected time of repair: ~12 hours (including a run to the hardware store, pre-prep, and clamping the new FRP section under there.
Suggested mitigation: never let your Caribou (or, wood-framed tub camper) sit directly on your truck's bed; place inorganic spacers under the tub, to elevate off truck bed, and allow air circulation !!!
S-
