RV 3 way refrigerator
Sondy132001
My RV frig is dead, the guy I bought the trailer from said it worked one day the next it didn't. I have been looking for a refrigerator for a year, they seem to be made of gold. Even the used crappy ones on Craigslist are $700. New ones are $1200 yikes almost more than I paid for my used trailer 😃
Is there a place online to find used rv refrigerators that won't break the bank ?? thanks for any info.
20 REPLIES 20
Old-Biscuit
Have you tried to operate it?
Does it turn ON?
What does it do....what does it not do?
They are not complicated..........power/heat source/liquid-vapor-liquid cycle.
Sometimes it is just a fuse/bad connection.....sometimes a control module.....sometimes the cooling unit.
But.....'fridge is dead' doesn't describe much.
Replacement cooling units can be purchased for >$500
And there are RV Salvage Yards
oakbowery
If you don't use the propane part of the fridge (which we don't) then I'd suggest just installing a $300 fridge from Lowes. That's what my father did in his camper when the fridge went out. We never dry camp and generally camp within a few hours of the house. He's yet to run into a situation where the food isn't still nice and cold even after a two or three hour drive (as long as you keep it sealed it'll generally stay cold several hours). Luckily my factory fridge hasn't died yet, but I suspect I'll do the same when it does. On my father's we just re-worked the wood framing around the fridge. It actually looks nicer now than before in my opinion. I'll post a pic of it this weekend as the whole family will be at the lake. My father was in the same position as you and didn't want to spend $1200 for a fridge.
2001 Dodge 2500 Cummins w/ 4:10 Rear
2009 Cherokee 31B TT
jaycocreek
You can replace the cooling unit for less than $500,probably alot less with an older unit. I replaced one a few years ago for less than $400 and it was like new again.
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
Sondy132001
yeah I'll do that, see if it's an easy fix ! It's a Norcold 874, from 1982 😃 I do have a manual for it.
APT
I would look for the model number and try to find an owner's guide. I have a Norcold and was able to find a troubleshooting chart. I used that to test and find my problem.
2017 Subaru Outback 3.6R
Trackrig
Have you taken it to an RV shop to be looked at? I might be some $25 fix?
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
