dadkins
Jul 19, 2013Explorer
RV toliet
I have a 2002 KZ Coyote Hibred. The floor of the trailer has gone soft and I have learned that this is a problem with this particular model trailer. I have removed all the linoleum and put 3/4 inch cabinet grade plywood on top. My quandary now is the bathroom. The toilet sits on the old floor which is shot. I want to recover the floor with the same material as the rest of the trailer. However, when I do this, the toilet will set almost 1 inch above the flange. Is there an adapter or something I can use to mount the toilet on the new floor and connect to the black tank? The toilet does not leak. It did previously from a cracked valve, but that has been repaired. I really need help on this.
