โDec-07-2020 03:43 PM
โDec-10-2020 12:00 AM
โDec-09-2020 11:56 PM
Lwiddis wrote:
Possibly. From where to where? Any wind in the forecast? Any sway prevention in the F350? Year? Your profile gives NO information. Stealthy? Doesnโt matter the length of your drive. You can get blown off the highway 5 minutes from home.
โDec-09-2020 02:03 PM
โDec-09-2020 12:33 PM
โDec-09-2020 06:19 AM
blaczero wrote:
Thanks all, we are looking at the 37' rockwood/flagstaffs with the bunkhouse floor plan.
Yes the WD is weight distribution. Looking at this one https://www.amazon.com/Equal-i-zer-Progress-90-00-1000-10K-Hitch/dp/B07RZV1SJ6
We found a nice flagstaff 832bws about 6 hours away in PA (we're in CT) and we mave have a great deal to get it this weekend!
โDec-08-2020 08:09 PM
jwoods61us wrote:
The RV transporter pulled it from Northern Indiana without WD or anti-sway, you probably can too.
โDec-08-2020 10:34 AM
dedmiston wrote:
Seven hours is a long way to white-knuckle a bad setup.
โDec-08-2020 05:28 AM
KD4UPL wrote:
You wouldn't necessarily even need a WDH with that combination. A 3500 will usually ride a lot better with a thousand or 2 pounds of tongue weight. I would have no problem towing it like it is at least until I discovered how it towed. If it turns out it would benefit from a WDH then go ahead and get one; otherwise, don't worry about it.
โDec-08-2020 05:08 AM
โDec-08-2020 01:22 AM
KD4UPL wrote:I experienced sway once.
โDec-07-2020 05:39 PM
โDec-07-2020 05:21 PM
Can you wait a few days to get the right equipment? There should always be time for the right gear.
โDec-07-2020 04:41 PM
โDec-07-2020 04:31 PM
โDec-07-2020 04:28 PM
