botrboy4
Feb 28, 2016Explorer
safe towing-camper package?
I need experienced advice on camper weight and towing. The last time I had a camper was a Six-Pac 8ft on a F150 SB and comfortably towed a 20ft boat, no hitch extension.
I now have a 97 F250 SB, 460V8. TorkLift StableLoad OL spring pads installed, AirBags are still an option. Class 5 2inch hitch.
I'm considering a used Lance 845 loaded (~3000#) or a lighter 8-8.5ft camper (multiple choices) that only weigh wet ~1600#. With the 845 I could get away with an 18inch extension with my longer trailer tongue. I think I could again get away without an extension for towing with the shorter campers.
Will I have white-knuckle moments with the 845 weight when towing on mountain roads (I'm a conservative driver)? Should I stay below a camper weight of 2000# when towing a 20ft on tandem axle (~4200#)?
Will it be the leverage of the hitch extension that will amplify the motion into the truck and cause those exciting moments?
I really would appreciate any experience feedback.
Thanks!
Thanks!
