c3saving's avatar
c3saving
SHADOW CRUISER 280QBS SAFETY CONCERN PLEASE READ
Many of you have has the axle issue. We have had it as well. The axles were replaced with the same weight and 4 tires replaced with radial tires instead of bias ply. Lippert took care of this.
This message concerns your main breaker box. Since purchasing the trailer, we have learned that we can not ask the trailer to run to many electrical devices at once or we will pop a breaker inside.
On our annual Labor Day trip, we continued to have a problem. This time I was able to look in the breaker panel not just the little door on a hinge. We have not been able to get the whole panel door off before. We found the insulation to our wires melted off. We turned the power back on after it blew again and found the wires smoking and one cherry red. Please check you wiring panel. This is above your LP frig. If one spark made it into the frig compartment, the whole thing would go up in flames.
If anyone else has had this problem, please let me know.
Thanks,
Carrie
