โOct-20-2015 10:11 AM
โOct-26-2015 09:14 AM
work2fish wrote:
Congrats on the retirement! I have 34 years at my employer and can see the light at the end of the tunnel.
I think you've chosen a good truck and now have to make a few decisions about the type of camping you want to do. I went through the same process a while back and you can read my post here.
I ended up choosing a popup which I hardly know is back there except for the occasional squeeking :). In my case I wanted to be able to hit four wheel drive trails, keep the camper light, pull a boat and make only minor mods to the truck. I bought the Torklift frame-mounted tiedowns which I would recommend and agree with most folks on CG not being too much of an issue if you get a SB camper. I also prefer the cassette toilet as I can dump most anywhere in a pinch and it helps me keep to my nomadic self.
Good luck and, again, congrats on your retirement.
Mike
โOct-23-2015 05:59 AM
โOct-22-2015 12:21 PM
Bedlam wrote:
Or just go to the source of these products:
[url]http://www.torklift.com/
โOct-21-2015 10:55 AM
โOct-21-2015 10:46 AM
โOct-21-2015 10:06 AM
โOct-21-2015 10:02 AM
nomadictxn wrote:
Congrats on the new truck Doc, and welcome to the forum. Airbags are not a requirement, just one of the ways you can deal with certain issues. As recommended earlier, try the camper out first and see how it handles and then start addressing any problems from there. You could bring them up on the forum and get steered in the right direction. I think most folks would recommend torklift products for your tie down system as well as a thick rubber bed mat. Also a way to plug into the trucks electric connector and you can go from there.
Happy camper hunting!
โOct-21-2015 10:00 AM
WVbassmistress wrote:
The Super-Truss extension is a hitch extension in case you want to tow something. With a camper that is longer than the truck bed, you will need a hitch that sticks out beyond that point. ie - we have 8 1/2 foot camper on 6 1/2 foot bed, so we have a 2ft (24inch) hitch extension so we can tow. Less overhang - shorter extension. The Super-Truss is kind of a double hitch, one on top of the other and chains that fasten to each side to limit side to side movement.
I hope this made sense.
โOct-21-2015 06:30 AM
โOct-20-2015 10:55 PM
โOct-20-2015 07:09 PM
โOct-20-2015 06:55 PM
โOct-20-2015 06:12 PM
โOct-20-2015 05:51 PM
Grit dog wrote:
I believe the long/short bed comment was for shirt campers that fit a SB truck but may not slide into a LB due to rear ovehang.
