GrodymanExplorerMay 02, 2016Shower LeakSo I have a leak at the shower drain, I think the p trap threading cracked. I think the factory didn't size everything properly and there is stress on the threaded p trap connection. Would it be wi...Show More
BB_TXNomadMay 02, 2016Mine started leaking last year and it was simply a loose fitting nut. Tightened it and no more leak. If yours is standard size plumbing pipes and P trap you could probably replace it yourself if it is cracked.
Related ContentShower fixture leaking behind shower wallHelp! Shower leakingShower LeakShower faucet leaking into hoseLance outdoor shower leaking
