DJK555's avatar
DJK555
Slide is marking the floor
On my 2008 Komfort TT I'm starting to get a worn spot on the floor where the leading edge of the slide floor stops when in. Has anyone seen this before and found a solution?
    Is the mark only where the slide edge sits when fully in? If so, it could be from the slide bouncing while under way when hitting potholes and the like.
    If the mark is a scuff from the slide opening and closing, then an adjustment may help.
    Our last tt eventually had both, in different places.
  • Slide Slickers will cure the symptom and keep the floor from getting scarred until you can get the slide adjusted. And maybe after that. Some slides simply cannot be adjusted to clear the floor and the ceiling at the same time (can we say "bad design"?)
    al
  • Had that problem on our 5er, was marking the floor at the center of the slide. Our slide a a big super slide abt. 14' wide. Dealer told me to get a slide slicker. Problem solved.
  • Slide is out of adjustment. I'd find someone who knows what they are doing and get it adjusted before you do some real damage.
