alexey75
Oct 03, 2022Explorer
Slide leakage
Hello guys,
Last spring we had a leakage, the water was coming in where the slide touches the wall. There was a bit of water, standing between the wall and the floor (front of the trailer).
I fixed the leakage, replaced the insulation (from the bottom), cleaned the mold. It wasn’t too bad.
The problem now, is that the floor a bit uneven, next to the leakage place. I don’t have a way to even out the floor. I will need to remove the linoleum and somehow put it back…
Question, is there a reason to remove the linoleum? Can I leave it as is? Can we breathe it (I am guessing there is a mold under the linoleum..)?
Thank you!
Thank you!
