slide out controller
xtruckerjim
Wilderness 29RL. I can't locate the slide controller. I've crawled around from one end to the other.
Anybody have a clue?
Jim
'04 Wilderness 29RLS
'05 Ford F-350 PSD CC 4x4
'97 Ford F-250 PSD(gone)
HD Road King KTM 450
5 REPLIES 5
WayneAt63044
My Forest River slide controller was laying on the floor under the pantry cabinet. The only access is by pulling out the drawers below the shelving cabinet which is near the power converter. It was not mounted in any way until I mounted it to a vertical surface in a position that I could push the button & read the codes - I still have to remove the drawers.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
xtruckerjim
Thanks for the hints. More investigating...
ssthrd
Mine was just inside the entry door in a panel with a flop out door which had both awning and slide controls.
Try here for info (hopefully).
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
wing_zealot
I have no idea where your’s is, but just to give you an idea of what the possibilities are, mine is behind a panel that is held on by 4 screws you can barely see; underneath the breaker box/fuse box.
spoon059
Where was it when you bought it?
2015 Ram CTD
2015 Jayco 29QBS
