โJun-24-2021 06:25 PM
โJun-25-2021 10:45 AM
โJun-25-2021 10:23 AM
MarkTwain wrote:Baja Man wrote:
So we made compromises....smaller TT, lighter weight,
Buy an additional holding tank that you strap to back of your RV.
โJun-25-2021 08:39 AM
Baja Man wrote:
Anybody use the 6 gal Igloo water containers? Howโs this process of storing water in truck bed and transferring to RV tank? Is a bladder preferred? Thought of taking 3-4 in back of truck.
Or a water bladder in rear of truck?
A 20-30 gal water tank would be too large and take much truck bed spaceโฆ, not as portable as individual water containers.
Thoughts?
I have an F-350 so plenty of payload,
โJun-25-2021 07:47 AM
โJun-25-2021 07:41 AM
โJun-25-2021 07:39 AM
โJun-25-2021 07:34 AM
bigorange wrote:
Is that 30 each black and gray or combined? If itโs 30 each thatโs comparable to what we have now and itโs doable. Gray is always our limiting factor. As others have said just be careful how much goes down the drain. If possible, can wash dishes in a basin and dump that outside if possible or down the toilet if you have separate black and gray. You could also use one of the portable totes for dumping gray assuming the campground has a dump station.
โJun-25-2021 05:49 AM
โJun-25-2021 05:35 AM
โJun-25-2021 05:23 AM
โJun-25-2021 05:09 AM
Baja Man wrote:
So we made compromises....smaller TT, lighter weight, easier to tow, easier to access locations, etc. Smaller, lighter TTs usually equals less CCC which equals smaller holding tanks.
The new to me TT has holding tank capacities as follows:
Fresh: 37ga
B/G: 30ga
Brochure on TT states 50 on fresh, but called Keystone, and per VIN, it is 37.
We mainly camp where there are full hookups.
Some state parks offer water and gray, but no black.
But when we do want to go where there are no hookups, how can we handle the limited tanks?
We travel most of the time with 3 adults......4 on occasion.
Thoughts?
โJun-25-2021 04:52 AM
โJun-25-2021 12:25 AM
toedtoes wrote:
As Mitch says, sponge baths.
Use baby wipes to clean up.
Use the campground bathrooms as much as possible (save the RV toilet for middle of the night needs).
See if showers are available at nearby campgrounds (in California, the USFS campgrounds are often in groupings and at least one will have showers that you can use).
If there is a dump station nearby, you can use a portable waste tote to empty tanks as needed.
โJun-24-2021 10:40 PM
โJun-24-2021 10:01 PM
