Smaller tanks
LITEPHIL
Has anyone gone from the 33 lb tanks down to the smaller 20 lb tanks? It's so easy to just swap the smaller ones out at just about anywhere.
2022 Chevy Silverado RST Duramax NHT
1954 Chevy 3100 Carryall 4x4
2008 Salem T23FBL
04 FXDL Harley
15 REPLIES 15
opnspaces
Navigator II
Navigator II
I have not but it should be an easy swap. The only things i see as a possible stumbling block is the length of the pigtails might require you to remount them lower. Also you might have to do some work to adjust the hold down bracket. But other than that they should work fine.
