I think the Bullet models use the foam core flooring which can, to some people feel soft, even when new. I would suggest you contact Keystone first to verify the flooring system for your trailer, some do have separate warranties from the general trailer warranty, and then if you are still concerned, contact a local rv tech, hopefully you can get some local references to use as a guide, and ask them to check/verify the floor.
