solar charger
poppa
i want to park my rv, 30' tt and keep the battery charged ( 1 12V BAT ) for now. what is the best way to do this. no a/c power available. thanks
7 REPLIES 7
campigloo
If Iโ€™m reading this right you will have it basically in storage. I have my original house battery disconnected from the coach. All I use it for is the tongue jack. I use a $15 solar charger from Academy and it keeps it nicely topped off. If youโ€™re just looking for a maintainer to supply the phantom loads on your trailer, a little plastic 50 watt or so plastic panel will probably work. The beauty of these is theyโ€™re cheap, no mounting required, no fancy controllers and will keep your battery charged.
Im holding on for the youโ€™re an idiot posts!
Boon_Docker
CA Traveler wrote:
Disconnect the battery (good for several months) or 100W solar panel and controller.
100 watts would do just fine. If disconnecting be sure to fully charge battery before disconnect.
Ivylog
100W if solar.
Upgraded with a 08 HR Navigator 45โ€™...
dodge_guy
I`ve got a 200W system in mind. basically just for if the power goes out in a campground (like it did for 5-6 hours on Labor Day weekend).
So if you are wanting to go solar, go with at least 200W, even 300 isnt that much more. but you will want more than one battery if you are going to boondock. otherwise for non use one battery is sufficient.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
obiwancanoli
Ditto on Solar... determine how many Amps you typically use in a day... 100W Solar will generate peak of about 5.2A... so... rough estimate, if you burn through, say 25A/day, you might consider up to 500W solar.
CA_Traveler
2014 Grand Cherokee Overland
Bob
jdc1
https://www.amazon.com/TP-solar-Monocrystalline-Controller-Connector-Z-Brackets/dp/B07S2B2QGV/ref=sr_1_3?crid=2FXY1Y64EO4H8&dchild=1&keywords=100+watt+12v+solar+panel+kit&qid=1600394473&sprefix=12v+100+solar+kit%2Caps%2C237&sr=8-3
