Some worry about payload……
4x4ord
And others, apparently, not so much:
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
16 REPLIES 16
Mike134
In all honestly once I stopped listening to the chickens with their heads cut off running around forums (towing police) and their nauseating ideas of the correct truck and payload to pull a little red wagon my towing experiences became much more enjoyable.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
lazydays
Looks like an ole beater to me.
Very Patient Wife
Two Boys & a Girl
2013 Keystone Avalanche 345TG
2016 Chevrolet Silverado 3500HD 6.6L
bucky
Put a truck camper on it. That will straighten it right out.
Puma 30RKSS
larry_barnhart
My friend had a heavy alpenlite. More weight than our alpenlite. His truck was a 1994 2500 dodge and the tail gate would fall down and he had to buy 3 new front basement doors because of the hole from turning with it down. He always said the bed would spread wider. I felt he was overloaded on the truck. chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
FishOnOne
Me Again wrote:
FishOnOne wrote:
We don't need no stinkin solid frames. :B
Or tailgates that will open if the frame is twisted a bit on uneven ground.
Tailgates typically won't open was my experience in a twisted frame bending mode
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
JRscooby
Solid frames? What uses a solid frame?
I remember a city uncle had a Chevy pickup, one of fancy ones that had no gap between cab and bed. We where behind in fields, but this uncle was pretty useless. Grandma needed chicken feed, so Granddad asked him to take his '51 Chevy half ton to town. Uncle knew Grandma would like the new pickup better. Friend from town brought Grandma and uncle home, because could not open cab doors.
Me_Again
FishOnOne
NamMedevac_70
I see dudes like this frequently on the 580 in Nevada. Usually carrying many super heavy rolls of carpeting, paver bricks, firewood, etc. and I keep my distance. Never seen one stopped by HP. They only do 5 over. Yep.
Grit_dog
Navigator
Navigator
fj12ryder wrote:
Groover wrote:
Was that an overload or is it just falling apart?
Yes.
:B
JRscooby
To me, it looks like was rear-ended, bending frame. Then to keep using they put a bed off a later model pickup.
fj12ryder
Yes.
Howard and Peggy
"Don't Panic"
Groover
Grit_dog
Navigator
Navigator
Mmmmm ceviche…..
