bkenobi
May 14, 2021Explorer
Space heater recommendations?
I recently took a trip to the midwest and was intending to use the propane heat in my NL TC for the sole means to keep the comfort in check and prevent potential freezing issues. The temperatures were in the high 20's a few times at night but up to the 50's in the day. As it turns out, we ended up staying at a location that had full hookups, so I stopped by Walmart and found a relatively compact space heater which saved me many trips to the fill station.
Although this was overall a great solution, the unit I bought had no thermostat but had high/low. The unit was 1500W/750W but on the low setting it produced too much heat for comfortable sleeping. I was thinking it might be nice to have a compact unit that had a thermostat and was safe to leave unattended (meaning no hot surfaces). Does anyone have a recommendation? I use an oil heater at home that includes a thermostat, but it's too big to travel with. A fan isn't critical but probably would be a plus.
TL;DR: I need a portable, compact space heater that is safe to leave unattended and has a thermostat.
