JoeAngelicchio
Sep 25, 2016Explorer
Spare Tire
Thinking of getting a camper but my spare stays in the bed. Where do you put your oversized spare? I've got a 35" all terrain.
Thanks
Joe
Thanks
Joe
stevenal wrote:Vinsil wrote:
Raise the camper! You already have a flat and most don't carry a jack strong enough to lift a truck with a TC on it.
Don't not complicate it.
Isn't the factory jack rated to raise a truck loaded to its GVWR? Easy to raise the camper as you say, but what if you were carrying gravel?
Bedlam wrote:
Something that has not been mentioned is the height of 35" tires may make loading and unloading of a truck camper difficult due to the height. The GM's will not fit 33's without modification or a lift kit, so I assume this truck is sitting on tall tires and a lift.
These 35" tires may not be rated sufficiently for carry a camper with all the features that are desired and you may need to scale back your wants or go to heavier rated commercial tires.
Your lift may may also not be the best choice for hauling a camper. Many are designed to allow for more wheel travel by using softer suspension components. This will result in unwanted sag and sway when loaded.
burningman wrote:True BUT the OP states he hasn't ever even checked to see if it would fit on his truck. So the FIRST step is to get the tire under there and see.
But this isn't a Ford!
I'll believe that moving a spare tire forward takes 300 pounds off the rear when I see it. Even though you're moving it from the almost extreme rear to the extreme front, that's a pretty optimistic number.
Perhaps it's true if your front bumper is extended about fifteen feet forward!
