handye9
Mar 28, 2018Explorer II
midnightsadie wrote:
how do you know the battery is ok, lok for main fuse or a cut off switch, IF you,ve done nothing different from the time you put it away? start at the battery clean post load test,any auto store does it for free.get a checp meter and follow the 12v line from the battery till you find the problem. I,m betting on a bad battery .
X2
2014 models hit dealer lots in 2013. Your battery could be five years old. Not unusual for battery failure at that age.
Primary suspects would be:
1. bad battery
2. corroded battery connections
3. battery shut off switch
4. blown fuse / short stop breaker (a pop-up may not have a short stop breaker)
5. damaged wire (maybe chewed by a mouse)
6. converter problem
In that order.
44,030 PostsLatest Activity: Jan 21, 2025
