Sep-17-2018 06:00 AM
Sep-18-2018 09:21 AM
ShinerBock wrote:Hannibal wrote:ShinerBock wrote:
Stock 2003 Cummins made 235 hp if it was an auto and 305 hp if it was a manual HO. The 5.4L in the Super Duty made 300 hp at 5,000 rpm. 3800-4200 is more than the 30% higher rpm you stated earlier. Lastly, I have towed 5-7k with a 5.4L SD and I don't remember it ever being below 4500 up hills. Maybe on flat ground, but not on hills.
The 235hp was California. Mine was 250hp. That was peaked at 2900rpm where it was starting to run out of breath. The 310hp 5.4L makes 287hp at 4200rpm. That's right at peak torque rpm where it's just starting to come alive. The 2010 lowly 5.4L out tows the 2003 SO Cummins.
Again, the math of your 30% more rpm statement does not add up. The 3800-4200 you posted is more than 30% above the diesel. This is going by your own statements. Peak horsepower of the 300 hp version of the 5.4L in the SD was at 5,000 rpm and peak torque was at 3,750 rpm, not 4,200.
Sep-18-2018 09:00 AM
Walaby wrote:
I believe the reason many people recommend using GVWR to ensure one has adequate capacity with their TV, is it would represent the potential worse case weight of the trailer, when loaded.
Sep-18-2018 08:48 AM
Me Again wrote:JTrac wrote:
When I shop for a truck the first thing I do is look at the little yellow sticker usually located on the door pillar on the driver's side. It will tell you how much cargo capacity there is for that particular truck. I was really hoping to get a srw last time around but most of the Ford diesel srw's in a King Ranch or Platinum had around 3200 pounds of capacity. The loaded hitch weight of our fifth wheel is 3100 pounds. Add the hitch at 180, us at 300, our 25 gallon auxiliary tank at about 240, filled, the 2 Boston Terrors at about 50 plus food and drinks for the day and we are suddenly bumping 4000. I could have gotten a different truck with less options to reduce the weight but not what we wanted. The dually has almost 5300 pounds of capacity.
I know most will tell you how much more stable, etc. a dually is when towing but honestly I cannot tell that much difference. We have owned several srw's in the past so I have experience with both. Our last srw, which towed our current trailer, had great road manners but we did experience a lot of chucking, probably because I had too much weight on it. That went away with the dually.
That little yellow sticker is a manufacturer's number based on GVWR minus weight of the truck's build. These have nothing to do with the federal bridge weight laws which the states enforce. Wadcutter who was a weight enforcement officer for years has explained this many times. Look at the GAWRings and do not exceed them. If your state licenses tonnage, be sure to purchase enough to cover your load. Chris
Sep-18-2018 08:36 AM
Sep-18-2018 08:28 AM
Wadcutter wrote:Durb wrote:
Can't see how these numbers add up. My truck has a gross combined capacity of 21,000 pounds. Since it weighs 8,000 pounds ready to tow it limits me to a 13,000 pound fifth wheel. Currently, a 40 ft. Big Country has a GVWR of 16k which would mean your F350 4X4 loaded up and ready to tow weighs around 5,000 pounds. I am glad you have towed it all over the country without incident. The numbers just don't appear realistic for the OP.
The numbers don't add to you because you're using GVWR. You must not understand what GVWR means. GRWR does not mean that's what the Big Country actually weighs. Gross Vehicle Weight Rating. Not actual weight of the rig. "Capacity" is not the same as actual weight.
And yeah, the number I gave are actual weights. I use to be the commander of one of the state scales and I weighed my rig a number of times when it was loaded various ways.
I do know what the weight ratings mean and the difference between "actual" weight and "capacity". I taught truck weigh laws for a lot of years, weighed a lot of trucks over the years, and was testified as expert witness in a number of cases involving truck weights.
You have to know what the terms mean if you're going to understand what they mean.
Sep-18-2018 08:17 AM
ACZL wrote:memtb wrote:
If the truck will be “dedicated” for towing....then a DRW would be very desirable. However....there are many reasons to consider a SRW. In our case, it’s a year round, do it all truck! It will be used in ice/snow/mud, hunting on narrow “ two-track” roads/trails, and the usual daily uses. For us the SRW is “handsdown” more desirable!
Our 5er is over 20K pounds....and we do fine! However, modifications (Ricksen 19.5” wheels with Hankook “H” rated tires) have been made to the truck, and the 5er has a good suspension (MorRyde) and hydraulic disc brakes, and 3 axles (17.5” wheels/tires)
It come down to how the truck is to be used the majority of the time.....and how much money, you’re willing to spend to make the SRW a reliable/safe tow vehicle for a heavy trailer!
If I'm reading this right, your stating that your RV alone weighs 20k and pulling it w/ a srw? If my fuzzy math is right too, 20,000 x 25% = 5,000 pin weight. If so, God bless you for you have bigger kahoonies than me.
Sep-18-2018 08:16 AM
Sep-18-2018 07:50 AM
Sep-18-2018 07:46 AM
Sep-18-2018 07:37 AM
Sep-18-2018 07:14 AM
Hannibal wrote:ShinerBock wrote:Hannibal wrote:ShinerBock wrote:
Never said your truck wasn't capable and this it cannot do it......eventually. I just said that the statement you made that your 5.4L SD will tow what a diesel can tow at only 30% more is a load of crock.
Eventually? We run the same speeds in every situation we ran with our diesels. Sometimes faster. My '95 Cummins was only 160hp. I now have twice the hp. The day 310hp isn't enough to tow an 8500 lb trailer is the day I'll give it up.
Are you seriously comparing a 2010 gaser to a 1995 diesel and figuring it is the same with today's diesels?
Also, you may have twice the hp at peak, but you don't at an rpm 30% greater than what your old diesel made its 160 hp . Your old 95 diesel made 160 hp at 2,500. Your 2010 makes 310 at 5,000 rpm. 30% over 2,500 is 3,250 and doubt you are even making 225 hp at 3,250 rpm.
Again, I am not saying you truck won't pull it . I am just saying that it will take more than the 30% higher rpm that you stated.
It's not all about how much peak hp the engines have or had, but how much hp is needed to do the job. I had three more Cummins Rams after the '95. Where the '03 250hp Cummins needed it's governed 250hp peak to do the job, the 5.7 Hemi and now the 5.4 Ford do it at 3800-4200.
Sep-18-2018 06:55 AM
Sep-18-2018 06:41 AM
Sep-18-2018 06:39 AM
Sep-18-2018 06:05 AM
