Considering tc that weighs roughly 3800 dry. Would a 1 ton single rear axle be okay or do I need to look at double axle only. Please, no truck brand wars. Stick to axles. Thanks.
Go with a dually. My Truck Camper a 2003 Lance 1161 dry weight 3919 lbs. E rated and/or higher rated tires, Torklift frame mounted tie downs. Possibly air bag suspension, definitely make sure of OEM truck camper package installed. If purchasing a truck obtain a build sheet from the truck manufacturer. Also weigh truck before installing the camper. Take a look at Truck Camper Magazine helpful advice. Ben
