Step for entrance, DIY
Francis
Our 1978 NuWa truck camper has a fold-down step, but as the camper sits high on the Chevy diesel, we have been using a MILK CRATE for a ground step and to get in and out. But we need to build a folding, higher and safer step to carry with us. I can do this, but would like some ideas on design, etc. THANKS MUCH.
1978 NuWa TC on 03 Chevy Silverado Duramax, with Airlifts, Tork Lifts and Fast Guns. No TV, no pets, semi-retired for a road trip with DW to Alaska 09. DW does all the writing and both of us are learning to play banjo!
23 REPLIES 23
toddb
Hooks
ticki2
Success ,thanks opnspaces , don't use the image box .
I discovered about a year after building them that they also work on the side rails of my flatbed , bonus
'68 Avion C-11
'02 GMC DRW D/A flatbed
BradW
Ok thanks. Just trying to understand. I'm planning some steps for our TC and anything helps.
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
opnspaces
Navigator II
Navigator II
BradW, forgot I was in the TC forum and was referring to building a step stool not an actual step.
opnspaces
Navigator II
Navigator II
Tiki, I see where you went wrong posting your picture and I only see it because it gets me all the time as well. You correctly loaded the picture to the site and copied the address. But you made a mistake of trying to post the picture by clicking on the yellow postcard icon.
The yellow postcard works for normal picture posting, but when you use the RV.net posting app you can't use the icon and instead you have to just paste the text right into the body of your posting.
The fix is easy, just edit your posting and in picture line you will see there is a double IMG one lower case and one upper case with square brackets at the beginning and end of your picture. Just delete the lowercase img's and brackets from each end and your picture will show. If you want an example of what I mean do a quote on AnEv942's posting with your picture and you will see how the address is different with only one IMG at the beginning and end.
Awesome steps by the way.
ticki2
Thanks AnEv , eventually I'll get it . The threads are dull because there is sand mixed with the urethane to make it non-slip .
'68 Avion C-11
AnEv942
ticki2 pics
The link provided by imgur should be pasted directly into text of your post-. looked at coding 1st picture is correct and would have shown but the second link is scrambled-last half of link is before the 1st? software kinda of merged trying to read?
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
BradW
opnspaces wrote:
If you build a step make sure it is wider at the bottom than the top. This will help prevent it from rolling under you r foot if you step on the edge.
I don't understand what you are saying here. I will soon be building some rear steps also.
Wake Up America
Supercharged111
I have a 25 foot stick of 1" square stock next to the house. I'm thinking I'll use some of that and that steel mesh to make a little 2 step dealie that doesn't hook to the camper since not all parking spots are created equal. I don't care how awesome glowsteps are, they're overpriced as all get out.
2007 Lance 1131
1997 GMC K3500 crew cab supercharged dually
ticki2
profdant139 wrote:
Tiki, try this for posting photos -- go to this link, upload your photo, copy the code that pops up, and paste the code into your message. When I say "code," it is a long string of letters and numbers -- just copy and paste:
Wonderful photo app by our dear mod 1492
That's what I did , either it's me or this old computer , actually we are both old .
'68 Avion C-11
profdant139
Don't know why it double posted -- I didn't do it!
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
profdant139
About our trailer
profdant139
About our trailer
ticki2
These are some steps I made from redwood ,only about 10#, they can fit though door and sit on floor . Trouble was they block the bath door for quick stops , now they go outside under the overhang . There is a bracket on the truck that the hooks go into and the back s bunggied to the step . Nice slope , almost stair dimensions
[img][/img]
[img][/img]
Sorry , guess I screwed up on the pics
'68 Avion C-11
