- TequilaExplorerThere is a mpdel that does not surge. If you go to camping world, you will find the cheap stock sureflow is about 45 dollars, the one you want is about 175 dollars.
- Dick_BExplorerOur Shurflo 4.0 is so quiet when the TV is on one can barely hear it but I have done several mods to make it so; probably some of the ones previously discussed.
- phishheadmiExplorer IIGreat, thanks for the advice...looks like I need to get to work on isolating the vibrations before I worry about replacing the pump! Great info, thanks again!
- Ron3rdExplorer IIIIf it's a decent pump, you can make it quieter by following the links posted by 2oldman.
- APTExplorerShureflo pick your size.
You may just want a bladder tank, liike Shurflo Accumulator so the pump does not run every time a faucet valve us cracked.
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 27, 2025
