WayneAt63044 wrote:
So far all the responses are from folks who recommend using such. In 30 years of RVing around the country I never needed one. Ran into a few pedestals that were worn or had no ground but never a major issue that put my trailer or contents at risk. A surge protector will not survive a direct lightning strike as it just isn't stout enough to handle all the Joules in a lightning bolt. Check with an independent electrician for perhaps a different opinion from those who sell power protection. Do you have such for your whole house? Have you needed it?
Ours has helped us around a dozen times. most were open ground, which by itself isn't a huge issue.
However it has tripped on low voltage several times. when the line voltage dropped to <100V, low enough to be a big issue with an AC.
as for whole house, not the same issue. House is not going one day have reversed hot/neutral and be correct the next day. Nor is it going to have 240V to 110 outlets one day and not the next. And is way less likely to have low voltage or high voltage.
But the above can and do happen at campground pedestals.
Surge. well yes it can have that
