Daveanddogs's avatar
Daveanddogs
Sw6p water heater
I just installed brand new sw6p water heater and all went fine. Filled tank, lit pilot, burner came on, then a small trickle of water started coming out of burner tube. What's up with that??
  • Daveanddogs wrote:
    Only happens when burner is fired up. I'll post a pic when I figure out how.
    The metal expands/warps from heat, warranty issue.
  • Only happens when burner is fired up. I'll post a pic when I figure out how.
  • Usually happens on older rusty water heaters
    That is a failure in production (over penetration during welding)
    Definitely warranty issue
    Sounds like a warranty issue.
  • Not sure. Did the leak continue after five minutes or so? Post a picture.
