gphoenix wrote:
How much benefit do you gain using 2 sway bars vs just one? Say for a trailer in the 30 ft. range.
Welcome!
And welcome to the world of towing a travel trailer, we assuming you mean travel trailer as opposed to an open flat bed trailer which is very different. If we knew more context on what the truck & camper are, if you already have a weight distributing hitch (WD), and what brand & size WD, truck cargo loading (weight), we can help give better comments on what is best for your overall towing setup.
Friction sway bars have a limitation on how effective they can be. Yes, 2 bars is better then 1 bar, as it doubles the friction. But there are many other factors on how to create a stable and comfortable towing camper that even 2 friction bars cannot overcome. Pending your rig setup, 2 friction bars may not correct all your problems.
Loaded trailer tongue weight, the trailer total loaded weight, the truck weights when hitched are within "all" it's capacities, the truck suspension size, the truck tire brand/size & pressure, truck aftermarket lift kits mod's etc, truck wheel base compared the the trailer length, and then, the WD hitch and what type of anti sway control all adds up to a good towing rig when they are all optimized.
Tell us some about your setup and we can help give you better choices and explanation on how to help make a better total towing package.
Hope this helps,
John
