Every tire has specifications and one of the columns is recommended rim width.
- Narrowest will provide the best 'Ride Quality" and the most sidewall bend back
- Widest will provide the best handling...for that rim width & tire...AKA smallest slip angle, and the lest sidewall bend back
Decide which is more important for youselves. Mine are 10" wide vs the tire recommendation of 8" wide for a LT265/75R16E. Exactly what I want: ride quality is horrible and the slip angle is very smalle
Better to use "Rev's per mile" to review the effect on your engine rev's/speed you wish to be at. Need your ICE's torque/HP curve to do so effectively. Along with all of the gear boxes from the ICE to pavement. Of course need the OEM info as a datum
What hasn't been discussed is the wheel off set. Ditto needing OEM spec in order to figure this out
Then measure both static and dynamic dimensions THROUGHOUT the travel for both sides of steering wheel lock to lock. That will tell if it will rub
Why more and more of the large installer corporations won't mount anything other than OEM for 'that' vehicle. Costco was one of the first to do so. Many independent franchise owners will, but they will have fine print to CYA themselves
This might help, but do so at your own risk (my CYA)...most fender sheetmetal will have a bend back lip on the wheel opening. That is the most likely part to rub, along with the forward and rearward corners. Get a 2" dia water pipe (steel) about 4'-5' long and roll it along that bendback to fold it upwards into the fender...but that will only solve the upper bendback interference
Have always loved over sized tires and have no problems with using a saw-zaw if needed on my trucks. Cars is another topic
