swhunter
Nov 09, 2018Explorer
Switch to 19.5" wheels & tires
Hello,
I have learned a lot by reading in the truck camper forum here. I just recently registered to become a member of this site. It seems like there are some really interesting and knowledgeable people on this site. I have been around the RV life style a very long time. My folks were fulltime RV’ers for twenty some years. I got into pickup campers in 1994. This is my first post; I am not very experienced at posting on the internet. Also I hope I am not beating a dead horse here since I know this subject has been here before. I just wanted to see what some of the people that have experience with SRW pickups and 19.5” wheels, tires and heavy campers, think of my situation and the way I am handling it. I want to go to the 19.5’ wheels and tires for the safety margin to gain with them.
I have 2000 Ford F350 with the 7.3 Liter Diesel engine, crew cab long bed, and single rear wheel pickup. In the pickup, I carry a 1992 Lance model 900 overhead camper that is for an extended cab or crew cab, which has an 11 foot 3 inch floor. I did put on the pickup the Rancho 2.5 inch level kit, which means it now has 4 leaf springs on each side of the front-end and it is double shocked and air bags on the rear axle. My pickup has 149,000 miles is still in good shape. As much as I would like to get a dually I don’t see that happening for a long time. If I would change anything I would like to go to 9.5 foot camper. I have taken the pickup and camper to a scale to be weighed. I have the following weights:
The pickup by itself with a full fuel tank, but no passengers.
The pickup = 7,770 Lb’s
The front axle = 4,560 Lb’s
The rear axle = 3,230 Lb’s
The camper wet weight, with everything in it full; water tank, propane bottles and everything needed to go on a long hunting trip = 4,770 Lb’s.
The weight of the pickup when the camper is on it, but no passengers:
Pickup and camper total weight = 12,540 lb’s
Front axle = 4,690 lb’s
Rear axle = 7,850 lb’s
Both the pickup and camper are kept in a non climate controlled pro-panel building when not being used. They are separated most of the time.
I contacted Rickson Wheel, and talked to a really nice lady by the name of Heather. Heather was very informative and helpful. I did tell her that I am interested in the 19.5” x 7.5” steel wheels that are rated at 5000 lb’s. After I got all the weight information to Rickson they sent me their suggestions on tires, which are: Toyo M608-245/70R19.5 – load range H – 16 ply, rated at 4940 lb’s. Said this tire is new from Toyo with identical tread as the M608Z.
Has anyone reading this had any experience they would like to share with a situation like this?
Thanks
Thanks
