alanaks
Apr 30, 2017Explorer
Swivel tongue jack options...
Moving my trailer has been somewhat of a pain in the butt, in part due to the fact that when I park it at home it must be in a very precise corner, which requires much maneuvering. Adjusting the wheel of the tongue jack to point in any given direction requires an excessive amount of force on my end while on my hands and knees, and often when I have it in the right spot it will simply spin back to a different position that is apparently more comfortable for it once I start rolling the trailer. This means I have to sweat getting the wheel to point the right way, and often physically hold the wheel at the right angle while others push the trailer itself.
Lubricating the tube is not the issue. I've considered getting a different jack that has a greater load capacity, and also considered just getting a different caster wheel, as this one is pretty chewed up, and I'm assuming that has much to do with ease of movement.
So my questions are...
What is the deal with jacks and wheels (that are meant to be bought together) being labeled as having different load capacities? If I'm mixing and matching (buying a new jack and a new wheel) for a 1500 lb. trailer then what should the capacity for both the jack and the wheel be? My current Fulton jack is rated for 1000 lbs...
Would just a new wheel most likely suffice, since this one is old and marred?
Thank you so much!
Thank you so much!
