allen8106 wrote:
I had a GMC SRW 2500 diesel and the truck pulled our 10,500 lb 5ver with no stability issues.
__________________________________________________
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
Grit dog wrote:
Rhagfo wrote:
"There is always two sides, the main thing to remember is the Payload Number on the trucks yellow sticker is the TOTAL of what the Truck can carry on it's wheels, not just how much pin it can carry. If your current TV is 2006 or newer, load as ready for a camping trip and go to the scales.
Take the total weight and subtract it from the Trucks GVWR, take that result and subtract that number from the maximum payload number from your yellow sticker, the result will be approximately how much of available payload you have already used before adding the weight of a 5er's pin."
Wow man, you've really changed yer tune since you upgraded trucks!
Still pot calling the kettle black if you now believe what you're saying after years of being cool with your ole 01....
But it's ok, prolly need to justify the purchase?
Just like I posted the first time to this my tune to others getting a new or new to them was to get at least enough truck to cover the load. I wanted a newer larger 5er, DW wanted a larger kitchen, I wanted larger bedroom and living room, no slide in old King of the Road. Last thing before we would sign the papers, was to drop the pin of the TV to check squat. Well it didn't then and even at 12,500# GVW and 2,700# pin the truck always set better than level.
The main reason for getting a newer TV was really three things;
1. The Ram had a NV4500 5 speed manual, there was a big jump from 3rd to 4th. I was looking at a G56 swap so $$$$ into a TV with 314,000 miles.
2. We full time, TV was going to be only vehicle, DW drove manuals for years, but didn't really like driving the Ram. Happy Wife Happy Life!
3. The 1,700# we were over GVWR! GVWR 8,800# and scaled 10,500# loaded, still within tire and axle, just CYA.
All That said I will say that 5ers have great towing characteristics even overloaded the physics are stable, tires are the weakest link. It scares me when post come up about "I have suqat" what should I do, and many answer blindly without knowing weights Bag it and go! The poster may be over loading their tires.
So all of that said old over loaded 2001 Ram and the new 2016 Ram with the same 5er.
