The dreaded "tank problem"s.... I am having trouble with both my gray tank and my black tank. 1) My gray tank is continuously clogged. I have to take a plunger to it about once a month to empty...
install a black tank sprayer and get that stuff moved to drain. if you have a permanent pyramid, use the hole cut for the sprayer and stick a pressure washer wand in there to blast everything. bumpy
