Doug33 wrote:
jerem0621 wrote:
I just use the burp theory of tank fullness measurement.
say what??
'Burp' method is an old tried and true method of knowing when to dump black tank.
Toilet 'burps' when flushing......level is high enough to partially block vent line.......therefore it burps thru toilet. TIME TO DUMP BLACK
Sink/shower drain starts to slow down....TIME TO DUMP GREY
Water pump goes 'burruppppp'....should have refilled fresh water tank.
I don't even look at monitor panel. Don't care if they work or not.
I know/learn how long before needing to dump...then I dump.
Just side note:.........don't care if 'clocks' work either
